WebODM Question
ddodell
Phoenix AZ
I am playing around with the web version of WebODM and can not figure out why my 3D imaging is not coming out in color. The only 3D file I see is an OBJ file, and it is a mono-chrome gray in 3D ... how do you get an output of a photo image in 3D. I inputed my 182 photos out of DroneDeploy after a short flight.
Thank you
I’m just fiddling with WEDODM. Try starting in 2D and you can adjust the opacity, ground cover (vegetation, rainbow colours etc). check they are set correctly. Then this will translate across into yr 3D Views. Also I assume yr original media are well exposed & coloured correctly?
have u figured out how to output in a format that others (without WEBODM loaded) can view? Results are great.
Manifest
