Weird thing and crash with active track
arjandevries
Hi,
I was doing an active track with my Mavic in the hills of the EIfel in Germany.
The drone crashed.
Here is the video, scroll to the last 20 seconds to see the crash.
Watch the whole minute to see whats happening.
The Mavic lost altitude and I do not know why.
Does anyone have an explanation?
We need to see the log, but I'm thinking that where the active track started and where it crashed had an altitude differential, which the drone is not smart enough to know, so it continued forward as though it was still above the ground. That, and obstacle avoidance during active track probably wasn't active.
When I am in the dji go app I can see the log files.
I can export to CSV
It says:
csv file locates at DJI go/documents
and than the name.
Where is this map DJI Go/documents located??
The explanation is simple. You used active track.
Sounds tongue in cheeky I know. Please don't be offended.
But I test flew active track quite actively (pun) in a controlled way to see if it was any good. I decided never to use it in any situation at all.
to me active track proved to be a gimmick, a game, a me too feature DJI needed to build in because they wanted the extra market of sports people who nowadays demand to be able to share clips of themselves while doing their thing.
agree.
active track is affective for keeping the subject centre frame as you pilot the mavic. not to jump on a bike and hope its going to keep itself out of trouble.
Not to be offensive but I watched several video's where it does a good job..
Sure. But I've also seen a lot of videos where it doesn't and crash for no apparent reason.
It is NOT SAFE.
Not even when you have you fingers on the control. It can suddenly accelerate and fly straight into the subject, in this case you, while controlling your motor bike instead of your drone. It could also suddenly decide to track something else, like another bike or a car. How anyone can decide that it is safe enough to have completely uncontrolled drone following a motor bike on a MOUNTAIN road, well, any road, is beyond my comprehension.
But that's what DJI wants the selfie generation to believe. I can't really blame people for actually believing the fancy marketing clips.
That's not meant to belittle or ridicule the young. But it is what it is. It is one big marketing mechanism that took the SM by storm, thanks to GoPro and the smartphone hype. And it's getting to become a problem. Even socially. If you don't share a cool action selfie you're very alone amongst all your facebook 'friends'. Sad, really. It's here to stay I'm afraid. Many people buy a drone purely for this.
Can you upload the flight log, to see if altitude had changed? Was OA off?
I thought the active track was for those on dirt bikes and skateboards, in a closed circuit. It records home point on take off, if you take it for a few km ride, part way through it’s going to turn around and head home. It was a risky attempt.
For every successful YouTube video, how many failed ones didn’t get uploaded?
Reactions: HighlandsVideo
I recently tested smart capture over the weekend, and that followed me running up and down a hill, changed altitude and everything. Don't know if it will work for a motorbike though.
Yep. I've had it follow a subject up a hill, but it was at close distance and only about 10 feet off the ground. I started testing it by walking up an incline. Then moved to following my Jeep up a hill in an open area. And finally driving on a trail through the woods with lots of tree cover. On occasion it wouldn't gain altitude, but most tests works fine. I just kept the controller close at hand.
I went through the eifel park over the weekend as part of a motorcycle trip, also with my mavic. Unfortunate about the crash but great area :)
I would like to uplod the logfile but...
I can find it is dji go app.
I can export the csv file
It says:
and than the name.
#3
yes it does, but not with elevation change.
I have had good results using it filming my daughter on a horse, but on flat ground.
I agree. I have had good luck with Active Track following sail boats, jet skis, etc. but the elevation of the target was constant.
boatdoc
