What is a flight?
seankimages
I'm a new Mavic pilot, and loving it! Had it about a week now.
I've been out on 3 separate evenings. I've flown each of 3 batteries until about dead each time. And I've landed and taken off again a bunch of times on each battery swap.
So, how many flights have I had? 3? 9? Or more than 20?
Reactions: ablack
1 flight is 1 take off and 1 landing. Btw check your flight records and you will find number of flight and also number of hour flying and total distance of flying !
Welcome here !
Reactions: Kilrah
The way that the logs record individual flights, is based on: Powering up > Taking to the sky > Landing and shutting down. Every time you swap batteries, you are starting a new flight. Technically, you could land mid-battery and take off again, but the logs will record it as a single flight.
I did several small flights to test Hangar with the same battery and my logs doesn't show me a single flight!
No! But I remember now that when you use Hangar, you have to exit Go4 app.... maybe it's the reason
Ok !
But still not convinced... last battery I did 2 fly of 12 minutes each. Didn't shut down the drone but just did a landing. 2 flights in my logs....
marcinhorj
