thanks for clarification..Most people will probably only use it to calibrate the Mavic sensors since the firmware can easily be upgraded from DJI GO. You could upgrade it using the DJI Assistant 2 though.
When I plug my Mavic into my pc using assistant 2 it says little pilot.Most people will probably only use it to calibrate the Mavic sensors since the firmware can easily be upgraded from DJI GO. You could upgrade it using the DJI Assistant 2 though.
