TONS and TONS of discussions about this on the board here. I am using an Acer Iconia tablet with Mediatek processor. A few others are using and have reported same good results. Some of the Acer tablets don't work. Seems like the ones with Mediatek processors do. Search for Iconia on the board and you will see the specific model numbers. About $ 65 dollars
Do you have the one with the MediaTek processor? Does it have any video feed lag?I also use Acer Iconia tablet and I like the way it works.
I have this Tab also and I have also found this sequence to work for me.Samsung Galaxy Tab S2 8" Sm-T710 and Sm-T713
Great tablets with 8 core processor running at 1.9Ghz, 3GB of ram, 32GB storage, GPS installed and all the other fancy bells and whistles you might not use.
Sm-T713 connects to the dji app in two ways
1. Power on the RC and Mavic doesn't matter the order, then power on the tablet connected to the RC and once you login the app will auto open.
2. If you already had all components connected and powered on, it doesn't matter the order, just restart the tablet. Once logged in the app will auto open.
Sm-T710 version will connect as normal, simple plug and play.
Lucky you, most users (including me) have found the A 7 unsuitable for running the Go 4 app reliably. (Though it was OK with Go 3). Even with all background apps closed, video caching off, hardware video decoding enabled and USB debugging off the tab had awful lag, video freezes and random error messages.I have Samsung Tab A7-no problems..
