Where do you mount Marco Polo gps tracker?
paulatkin73
Massachusetts
Hi, i cannot decide where to put it. I would prefer to mount it permanently, but, in a way that would not obstruct portability and transportation of it when folded down. I have Bondic, so it will weld it to the body fine, but, where...
Where did you put yours?
You can find a bunch of commonly used mounting locations here.
I was more interested to hear from people here than to look at google showing 3d printed holders i absolutely have no interest in seeing...
Those photos show nearly every possible location a Macro Polo tracker can be attached to a Mavic. Maybe just ignore the photos of the 3D mounts if that's not what you want?
If digging through threads is more to your liking, you can find lots of existing threads in these search results.
Reactions: tleedom
When I get my new MAVIC 2 I am going to try this mount. Cut or remove somehow the bolt.
PGYTECH Mount Adapter For DJI Mavic MAVIC 2 PRO / Zoom , 1/4 inch Thread Connector Quick Release For Sports Camera Accessories
Available from AliExpress.com
Also Amazon at an inflated prices
There is also this available from AliExpress.com which could be adapted
. Both easy to remove.
New Connection Adapte Connection Holder Mount Connector for DJI Mavic 2 Pro Zoom Camera Accessoriesfirefox_2019-01-28_01-54-35.pngfirefox_2019-01-28_01-54-35.pngfirefox_2019-01-28_01-54-49.png
Velcro on the side
got mine on the front arm, on the outside so arm can still be folded and can also plug the charger into it, added a bit of tape around the tracker as I didn't trust just Velcro
@THE WOMBLE
Apologies to both @Aerial-Pixel and @msinger for my earlier gaffe.
With Aerial-Pixels mount on the rear arm, the arm will not fold against the body without flexing / spreading the rear arms a skosh. If I spread the rear arms a bit I could fold it against the body but I choose not to. I have installed and removed it many many times (approximately a hundred or so) and it shows NO signs of fatigue.
I personally would not attach an electronic transmitter on the antenna legs. It might be OK but I choose not to.
@THE WOMBLE
Where exactly are the Mavic 2 antenna(s)?
polor pro does not transmit until it is activated by the track function on the hand unit. until then its dormant
hesitantextraneous
