Which controller?
wco81
Some people rave about the RC2. The brightness of the screen is worth the expense they say.
From my POV, I’m coming from a Mavic 2 Pro which has a tiny folding controller, probably lighter and smaller footprint.
They tout the Air 3S as a travel drone. The aircraft is lighter than the Mavic Pro drones but these new controllers, even the ones without the screen, look huge and heavier.
Is there some functionality benefit to having the integrated screen, offsetting the greater weight and expense?
There have been times when I’ve had issues connecting to the aircraft, maybe because the cable to my phone wasn’t secure. So it would be nice to avoid that kind of glitch.
I got the RC2 but I’m not really traveling with it. I’m a home inspector and often my phone would dim when using the controller during the summer when I was flying my current Air 2. . I also have an issue where the app will not stay up long enough to transfer more than 8-10 photos at a time. I wanted to go with a separate controller to hopefully pit these issues behind me.
Most phones have a setting where you can manually select the screen brightness. In bright conditions I set it to maximum brightness when flying, and it does not dim.
Your other issue should also be solved with a setting in the phone, often in a "save battery" setting.
If you do not need the option of flying with a bigger screen ...say an Ipad... get one.
If you wanna fly with a larger screen, Skip the screened controllers, you cannot output to a larger device while flying when using the screened controllers. That is for the pro model controllers and unscreened versions only.
My take, I prefer separate screen and controller for several reasons.
Flexibility of choice of screen size being one, clips are available that allow the use of tablets with the 'dumb' mavic 2 controller etc etc.
IMO, the connecting and disconnection of cables is the work of 1 or 2 seconds and of absolutely no inconvenience.
I’ve never used iPads, just iPhones. My current iPad is the 13 inch iPad Pro, way too big to use for controlling the drone.
I like separate controllers as well since it makes it easier for resale.
Reactions: Yorkshire_Pud
I thought the RC2 display was like 7 or 8 inches but it's 5.5 inches.
My iPhone 16 Pro Max display is 6.9 inches, though it has wider aspect ratio.
I’ve tried everything. It is a feature of all the iPhone pro/pro max with oled screens. When it gets warm it dims way down.
Thinking about this choice again.
Has anyone traveled with either, wondering how the difference in size and weight is holding up.
Also, does the RC2 support long-press on the screen and then dragging to control the gimbal, like panning left and right, up and down?
Does the RC-N3 connected to an iPhone still support the long-press control of the gimbal?
I recently traveled with both and preferred the RC-N3 with mini ipad mini 5. The larger screen outweighed the convenience and extra controls on the Rc-2.
DayTrip
