Which fly app compatible built-in-screen controllers, if any, give access to the flight logs via USB connection to a computer ?
Works fine as it is.Should I turn it into a 'poll', if I can ?
There are various alternative solutions which I think involve using an mSD card in the controller and using the controller's 'file browser' to copy the files from their original location to the card and then put the card in a reader attached to the computer blah blah blah. But, to me, it appears to be much easier to copy them via USB as I do with my phones.If you find a solution/answer, let me know! Now that DJI sync is off, I have to connect a microSD to my smart controller, and search the controller for the correct file (sometimes mysteriously stored in Drafts) and then transfer to my computer, then upload to DroneLogBook.
could you perhaps give the paths/folder-chain, as seen on the computer, for the controller/s you have please ?They can all be connected as an external USB device, allowing access to files.
bearing in mind that some people struggle to copy them to a memory card in the controller could you explain "dlb-sync and uav snyc" please ?Rc pro allows you to use dlb-sync and uav snyc to platforms, if you have adb access to your RC / RC2 you might be able to install these apps so they can sync directly to cloud
you will need this for dronelogbook:bearing in mind that some people struggle to copy them to a memeory card in the controllercould you explain "dlb-sync and uav snyc" please ?
Thanks but can those be installed on the "fly app compatible built-in-screen controllers" ?fly app compatible built-in-screen controllersyou will need this for dronelogbook:
DroneLogbook Companion. - Apps on Google Play
DroneLogbook Companion Mobile Applicationplay.google.com
or this for airdata:
yes, some android experience is kind of a requirement for this but the learning curve is steep![]()
