why can't mavic 2 pro save images on sd card using drone harmony
amethiel
We were trying out cell tower inspections with the drone harmony app using mavic 2 pro. There is 64Gb SD card inserted in teh drone, but the images are still saved in the internal memory. SO the internal memory gets used up midflight, the mavic still continues with the flight, but the images can't be saved even in the sd card. Isn't the sd card supposed to be the default storage? Is there a way to set where the images will be stored?
make sure its set to save to sd card in setting. or your sd card isn't fast enough so defaults to internal memory
The app should have a choice in its settings. If it doesn't becasue it wasn't updated to support all the M2's features you'll have to use GO4 to change the setting then switch to the other app.
sorry yes I see its Drone Harmony do like Kilrah use dji go4 first change settings than use DH
Marcc
