Wifi mode password problem
keyframe
Is it possible to change the Wifi mode password without entering wifi mode?
I've changed the motherboard due to some reason earlier, everything works fine. But recently I try to connect wifi mode, and the password is incorrect .
I realize my wifi ssid under the battery is different with the ssid on phone.
I also heard that the default password is 12341234, but it only apply on old version of Mavic Pro, I believe mine is a newer version and it has an individual password.
So what can I do now.
Had to do this the weekend
Put it into wifi
Connect mavic to computer
Open assistant 2
Wifi tab tells you current ssid & password
Connect via wifi using device for go4 app
Go4 able to change wifi password if you wish (not needed as phone / tablet now connected)
Reactions: keyframe
Put it into wifi
Open assistant 2
Thanks its work , I found the password inside the DJI Assistant 2 app
binhviet2004
