Will radio mast interfere with control -Mavic 2 Pro
PaulRMason
UK
Hi guys,
I've been asked to survey a roof at a hospital, which has a couple of masts on it. I've tried contacting DJI for advice but haven't got a response. Anyone know where or how I can find out ?
These are the transmitter details that I'll be working near:
Location 1
Base TX 453.275MHz
Base RX 459.775MHz
12.5 KHz channel width
Base antenna ERP 4 Watts
Portable ERP 4 Watts.
Base TX 453.6125MHz
Base RX 460.1125
12.5KHz channel width.
Base antenna ERP 5 Watts
Portables transmit power 4Watts.
Location 2
Base TX 453.1125MHz
Base RX 459.6125MHz
Base antenna ERP 2 Watts
Portables Transmit power typically 4 Watts
Location 3
Base TX 456.675MHz
Base RX 462.175MHz
Base antenna ERP 3Watts
Portable transmit power typically 4 Watts.
Any help would be great
P
You will have zero issues with anything on drone side...well unless you hit anything up there...take care.
Reactions: jimlips and Jay241
Should be no issue. The power levels are similar to a standard handheld transceiver.
You will be operating at much higher frequencies in the 2.4GHz and 5.8GHz bands so no issue with radio interference.
CTD
