Will this charger work?
If you look at the CS manual you will likely find that phantom 3 pro charger is listed amongst those specified, this should work if it meets or exceeds spec.
Thanks for your reply. Looks like it’s gonna do the job. I was just worried about it being sooooo cheap that I might have problems.
Price wise, it’s a bit different to the Dji chargers they recommend. Bummer.. just sold my Inspire:rolleyes: I had to let it go with it.
It should work.
Thought it might, ive read a review on Amazon about a very similar model & the reviewer uses it solely for charging his CS batteries. He loves it. Bit of a dumb deal & very cheap.
As long as the polarity of the connection is correct it will work fine. There's no magic in the CS PSU requirement. I'm using a $9 Laptop PSU but I had to open it up and swap the tip and the ring on the connector on the circuit board. While I was at it I 3D printed a new case for the board to make a nice compact package.
Reactions: Porky
Many thanks for the above info. One guy remarked on Amazon that he only uses that PSU for his crystalsky charging, that did put my mind at rest;)
Bought it but not used yet..
I’d love to answer your question but with the CS, bracket & mount, charger.. they are all wrapped & sitting under our tree ready for 25th of next month. All I had to do was resource it, do some homework, didn’t want to pay the amount Dji wanted:oops: then order it. If you look at the reviews, it fits the bill;).
Sorry for being sooo vague;) the link below is not the same as my previous link in post #1 but this one crossed all the boxes
https://www.amazon.co.uk/dp/B01GYILJ3I/?coliid=I3OSYZLCSW2PL2&colid=3O3KVA82DUY0&psc=0
It works, I’ve had this a couple of weeks now and used it twice without any problem. The plug just plugs into the battery charging block.
Reactions: Porky
Cool, I ordered this a few weeks ago, many thanks for the clarification it works, I only went with the comments that was posted on Amazon. BUT can’t use it until the end of next month:rolleyes: yep it’s sitting under the tree...well it will be when we put it up..;)
hello hope thos helps , i use the CS to Mavic adapter charger cable & works awesomely
great...! View attachment 57983View attachment 57984View attachment 57985
That is a great option, wasn't available when I bought the Phantom 3 charger. I still haven't bought a multi charger for the Mavic2. I was going 3 times a day with the Mavic pro. Most of that was training. I'd buy it if I didn't already have the Phantom charger. It is bulky, but I don't need to charge the CrystalSky very often!
tagir
