World direction vs compass interference
Somewhere in Peru
Problem? I cannot calibrate compass. Unit is flying well (no drifting, RTH works) but with constant compass problem. How I force him to fly? See the video a then read below.
Was unit in a crash? not yet
What have you tried so far? Normal calibration and super calibration - a lot of stupid moves, turns, twists while calibration, I tried everything (I think I could make a mavic calibration dance with all those moves), no metal objects or anything nearby, many different locations
What device are you using (iphone , ipad, Samsung , etc)? Iphone SE (airplane mode)
What firmware are you running ( aircraft, remote controller)? Aircraft 01.00.05000, Remote 01.00.0200
What Go app version are you using? DJI GO 4 version 4.3.10
Any modification?
(if so what) no
Did you change anything or install any apps? (if so what) no
And the video :
How I make this bird fly? As You can see on video the compass interference is changing depending the directions of the world the aircraft is pointed at. I just find the direction in which the interference is low and reboot the aircraft. After that there is no compass error and I can take off. Of course when I change the direction while flying I got message that there is a compass problem. RTH works well. No problem while flying.
1. Could You guys check if the changing world direction affects interference in Yours Aircrafts?
2. I read a lot of compass problems in this forum and I think Cfixer would do the job. Do You know anybody in Peru that have one? Or even south from Peru because I am going south until I get to Ushuaia.
My unit I bought in USA - if it's changing anything.
Ok problem solved. I left my MA to official DJI store in Lima, Peru and asked them to repair it. Firstly they demagnetize my dron using small demagnetizer which didn’t work. After I begged them to try something else they used huge demagnetizer.
Now dron is working as a new :)
BTW
When I was picking up my drone I meet a guy which had same problem.
Demagnetizing seems to solving compass problems.
Reactions: sar104
jageist
