Yaw error, if the drone had clear airspace would it result in the drone flying a circle?
Just a clarification...
A circular path in a yaw error incident comes from a compass deflection of around 90 degrees when the IMU is initialized. The path becomes straight when the deflection is closer to 180 degrees.
Ok and thanks .... do you have a flight log etc. ?
dvkhamtruocsinh
