I can't say for sure about your particular situation but for me, the problem was not the actual footage but rather my computer. When yawning every pixel on the screen is rapidly changing and my older system just could not handle it. It skips frames and makes it appear to jerk. If you can try the same footage on a faster computer - maybe a friend has one. Or try rendering the stuttering file to a lower bit rate - as if you were going to post it on YouTube and see if your system plays it smoother. Either one should reveal whether it is the footage or your system. If the fault is in the original file it should always play exactly the same way and jump at the same points.
Is your firmware up to date? I had some annoying jitter when the drone was still on 1.0.2.Thank you very much for your reply. I’ll definitely look into it. Although I use the same hardware and software (iPad Pro 2020 and LumaFusion) with my other drones (Mavic 2 Pro and Zoom and Scadio 2), no problems with those.
