Check the original post.
DIY 444WH (120,000 Mah) Power Bank for charging drone batteries at the field.
I want to share one of my projects that I finished to charge batteries at the field, but also can charge any USB-C/A device including 2 120W port charging. This DYI power bank using 24 Cells of Samsung 21700 5000 Mah 25C can produce 444 Watts Hour or 120,000 Mah of capacity. Can output 320W...
mavicpilots.com
