MavPro75
Same here!I second what he said
Obviously ones mileage varies. 4G phone connection here and updates via Go are a breeze for me.
I did the following:thanks for this i will try factory rest too to see if my range improves. question, after factory rest did u have to do front Obstacle Avoidance cameras calibration (with the Assistant tool on the PC/laptop screen) too or just IMU, compass and RC?
...Edit: Since posting the above I managed to make a .0400 test flight. The result is the test flight went very well. The differences I saw with the video display in the screen while flying was huge! I was amazed at the actual video quality. There really is that much of a difference that it needs brought up. Now the only issue I ran into was when I was almost back to HP. I started getting a audible beep after I cancelled RTH to fly manually. It was stopping the A/C as if I was closing in on a object. I do not have that feature enabled, but I believe it has something to do with flying directly into the sun? But if the rest of my flights go as well as this test flight, I will without a doubt be on .0400 for a longtime to come.
I read this a few times, and still can't figure out which firmware had the better display... Maybe I'm just too tired, and I should re-read it again in the morning. I assume that it was the .400 that had the better display. I noticed far fewer breakups and artifacting on .700 than on .400 on my maiden .700 flight.
I Bailed Out on .0700!
This post is continued from details I posted back on page #14.
Since making the post on page #14 about how things were going ok since upgrading to firmware version .0700 I made another flight that changed my mind. My plan was to fly some distance on the next flight. The weather today is simply awesome at my location. Low humidity, clear blue skies, occasional 5-7mph winds. Anyway the flight started off normal. When the Mav reached around the 8,000ft range the video froze and would update just 1 frame around every 30 seconds. After about 90 seconds of sign of improvement, It was time for RTH. No problem with RTH, the flight map showed the mavic was in route to HP. I was able to still see the altitude, speed, ect. So I lowered the altitude gradually the closer it came to HP as I usually do. The video issue remained in the same state, it never improved or became worse. I landed and went straight to the pc and loaded .0400 in both the A/C and R/C. I have all settings adjusted and just need to make a test flight with .0400 here soon.
Anyone experiencing video downlink interference after upgraded to 0.600 or 0.700 at the same location prior to upgrade ?
After I upgraded to 0.600 and then 0.700, my Mavic became more sensitive (prone) to interference at same location which had no sign of interference before.
Right after the interference occurred, video downlink totally cut off left only black screen on my phone (the same happened when I used an iPad mini) but all other data are still active and available on screen. The Mavic was within line of sight, so I was able to use RC to guide it back. On one other occasion when the same interference happened, I used RTH to get the Mavic back.
Also, after upgrade to 0.700, my Mavic also had gimbal tilt problems.
Yes I had more sensitivity to interference and video / gimbal acting strange. Back to 0400.
Thanks for sharing!I had a similar experience while using the mini 2. I reverted from .0700 back to .0400 and now everything is much better.
