- Joined
- May 27, 2017
- Messages
- 14,458
- Reactions
- 19,469
- Location
- Los Alamos, NM
- Site
- www.mavicpilots.com
This is turning into rather an abstract discussion of set theory, but to ask the question differently, if Part 107 does not apply to flights made under 44809, in what way do you see 49 U.S.C. 44809 as being "inside" 14 CFR Part 107? They are entirely different regulatory frameworks.IMHO, I believe your (umanbean‘s )diagram is directly on point and correctly depicts current FAA and statutory rules. I base this contention primarily on 44809’s Federal Register notice (at Exception for Limited Recreational Operations of Unmanned Aircraft) which states:
“SUPPLEMENTARY INFORMATION:
I. Background
Recreational flyers must adhere to all of the statutory conditions to operate under the Exception for Limited Recreational Operation of Unmanned Aircraft. Otherwise, the recreational operations must be conducted under 14 CFR part 107.”
This is also found under AC No: 91-57B (https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_91-57B.pdf):
7.1 Statutory Conditions. Until further notice, paragraphs 7.1.1 through 7.1.8 provide guidance on how a person may meet the eight statutory conditions of the statutory exception of 49 U.S.C. § 44809 to operate a UAS for recreational purposes. A person who fails to meet any of the statutory requirements of 49 U.S.C. § 44809 may not operate UAS under the statutory exception and would need to operate them under part 107 or any other applicable FAA authority.
(emphasis added)
I certainly respect the opinion, knowledge, and experience of the pilots in this forum. However, based on the words of The Federal Register and 44809, I have to conclude that umanbean‘s diagram correctly depicts current FAA rules.
I would add one other thing for consideration. The word “outside” is different from the words “does not apply” since they have different meanings and should not be used interchangeably.
If my analysis of 44809 above is incorrect, I would greatly appreciate someone explaining what I am missing.
And what you quoted above clearly states that recreational flights conducted under 44809 do not fall under Part 107:
How is not flying under 14 CFR Part 107 construed as being inside Part 107?
