DJI RC firmware update to V01.03.0400
Aquaelie
MN, USA
Hey all! Wanted to check in with you and tell you that I discovered as of 8/9 that my DJI RC shows an available update to 1.03.0400
The size of this update is 876.06 MB and only details that there are some minor bugs fixed (can’t be that minor at 876MB!!)
I don’t know if this means it bring compatibility with the air 3 or other craft but I’d someone can check this out and confirm it would be greatly appreciated
DJI RC Release Notes
Copyright © 2023 DJI All Rights Reserved
Date: 2023.08.08
DJI RC Remote Controller Firmware: v01.03.0400
DJI Fly App Android: v1.10.0
What’s New• Fixed some minor bugs.
I've learned by experience to be wary of large DJI updates that "fix minor bugs", especially considering the fact that there's no obvious sugar coating (such as a funky new feature to sweeten the underlying bitter pill). I now leave the testing of new firmware to others for at least a few weeks and check to see if there are warnings posted on YouTube. After that time: if all seems kosher, then I might update my bird.
Recent case in point: the FLY app update that removed the option to set altitude higher than 120m... The one that DJI rapidly followed with another that switched that option back on because their loyal users were going bananas.
Reactions: Marco Luz
Is there a way to downgrade to 1.03.0100 version? I've tried to find it on the web but without luck
Not to my knowledge although i keep seeing the phrase ADB which i believe means some sort of debugging access that would allow you to install a firmware lower. I haven't spent too much time looking to be honest but i suppose if we could get the image of a lower firmware it may be possible to reinstall it. There is, as you say, very little info about it.
It is NOT the drone firmware you need to downgrade. It is the hand controller. Dunno if this software does that.
EDIT:
NO it only does the aircraft FW, not the controller.
You can download firmware version 01.03.0100 from here:
Oh niiice !
This is what I was looking for .
I have already update my RC to v.01.030.400 but I want to downgrade the FW so i can hack the Mini 3 Pro with the FCC mod.
Does anyone know how i am supposed to install the .bin file to my RC controller ?
أوه لطيف!
وهذا هو ما كنت أبحث عنه .
لقد قمت بالفعل بتحديث جهاز التحكم عن بعد الخاص بي إلى الإصدار 01.030.400 ولكني أريد الرجوع إلى إصدار أقدم من FW حتى أتمكن من اختراق Mini 3 Pro باستخدام تعديل FCC.
هل يعرف أي شخص كيف من المفترض أن أقوم بتثبيت ملف .bin على وحدة التحكم RC الخاصة بي؟
hmmm interesting .But some parts missing .Which Hack can i sue and where can i find it ? Does it really works with this ?
It seems that you must have a Andorid phone for that .
Give me some more info please.
Thanks!!
Unfortunately after update to 1.03.0400 mod fcc (old version) is not active anymore. New version of mod survive update to .400 but if you had old version of hack and install .400 firmware there is no way (I hope so far) to make hack working again.
After updating patch fcc to v.100 and then to 400 fcc is permanent or can it disappear without the possibility of re-uploading after resetting the controller?
I've tried to downgrade dji rc firmware with a little hack through the dji assistant 2 (consumer drone series) but failed. It was failed after "Transmitting" part of the updating process on Updating 3% stage. So now you can't downgrade dji rc firmware if 01.03.0400 installed.
dji rc I can't downgrade for the fcc patch to work, I downloaded the previous firmware from dankdrone but because of rollback it doesn't install, is there any solution, adb doesn't open to see files from adb controller
bullet_magnet
