For easy transport of my MM
Those aluminum cases are a bargain. Here in the US, same price. Pluck some more foam and add your other accessories (ie. batteries, cables, chargers, etc.) as you grow. Wish you well in your flying.
Reactions: Capt KO
Lol. Luckily i have few pelicases witch I'm not using. They are best because of foam possibilities..... but they are rather expensive. Nice solution ☝?. I think best way to go will be foam from pelicase inserted into your case. They foam isn't costly and it's made for this sort of things
Nice idea... ready to use, easy unpack ;)
Where do you get the cheap cases? The ones I’ve seen locally are expensive. Thanks.
They used to stock them at Home Depot and Lowes, Harbor Freight, also. I used to buy them to organize my magic shows and equipment. $20 with pluck foam and dividers. Prices may vary. Here is an example: Aluminum tool case another example: Aluminum case
Hope this helps.
I use a Pelican 1200 for both my MM .MM combustion in case.jpg and MA MA casejpg.jpg As you know the case is durable, water tight and both fit well in my flight bag. I did treat the pluck foam with Plastic Coat for added durability.
Reactions: Dbez1 and m80116
Beluga
