Hello from New Hampshire
RoyGNH
NH
Hello all! New member to the forum. Been piloting the Mavic Mini since it was released, and now flying the Mini 3 Pro. I have my TRUST cert, a Systems Engineer by profession and hobbies include photography, Ham Radio, Microscopy and Amateur Astronomy. I’ve found this forum to be very helpful, and finally decided to register as a member. Have about 18 miles logged so far on the mini 3 pro, and over 60 miles on the mini. Look Forward to participating in future discussions as a member of the forum!
Hello from the Crossroads of America RoyGNH.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
OK, I TRUST you've done all the legal stuff…
But since you live in New Hampshire, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini and the Mini 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy, Safe and Legal Droning…
Me too - Fitzwilliam. And yes, the scenery is spectacular.
Ever in Keene? We three should meet over a cup of coffee sometime. I work part time at Keene State, and fly their drone under a part 107 waiver for atmospheric data collection. _JC_
You're just down the road a bit. I'm up in Dublin. My biggest flight problem is wind, which is pretty strong most days...probably better down in the valleys off the ridge here?
You ever go to Harrisville? It's a beautiful place to fly.
Reactions: LoudThunder
twentytree
