Hello from the south
Looking forward to seeing what I can do with Air 2S!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in "Lower" Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. I have family living in LA, Crenshaw County. We look forward to your participation and your view of the world.
When people say, "hello from the south" I am never sure if they are talking about Alabama, Mississippi, or Montana...
As you wrote in your Signature, "Quite possibly further north than you," a member could be from Anchorage and still write "hello from the south" and as far as you are concerned, they would still be correct… L 😁 L . . . 🎅🦌🦌🦌🦌
Reactions: RodPad
@LoudThunder
The OP first post.
"New member from LA (lower Alabama). Looking forward to seeing what I can do with Air 2S!"
Your twisted humor has past mine.:)👌
If I'm missing some thing send me a PM.
I think I can delete this within 48 hours?
Rod ..
The OP first post.
I think you got the joke, the member AKDrone is located in North Pole, Alaska, and in his Signature Block, he put, "Quite possibly further north than you" and he joked about the OP's reference "hello from the south" and he then went on to mention Montana as being South… I for one never considered Montana as being South…
Since AKDrone's home is at about 65 degrees North Latitude and of the hundreds, even thousands of members in the MavicPilot Forum, only a few members in Greenland, Sweden, or Finland are further North than he is…
So, as the old joke goes, I take you on a little trip and when we get there, if I blindfold you and spin you to a circle a couple of times and then tell you that you are now facing south and I tell you to turn 90 degrees to your right and I again ask you which direction are you facing and you say West and I tell you, No, you are facing South. Where are you?
You are on the North Pole and no matter which direction you are facing, you are facing South… L :D L . . .
Reactions: RodPad and wjkrysak
I’ve been to the North Pole & live in Montana. Seems like everything is South!
anton13
