Hello from the south
I think you got the joke, the member AKDrone is located in North Pole, Alaska, and in his Signature Block, he put, "Quite possibly further north than you" and he joked about the OP's reference "hello from the south" and he then went on to mention Montana as being South… I for one never considered Montana as being South…
Since AKDrone's home is at about 65 degrees North Latitude and of the hundreds, even thousands of members in the MavicPilot Forum, only a few members in Greenland, Sweden, or Finland are further North than he is…
So, as the old joke goes, I take you on a little trip and when we get there, if I blindfold you and spin you to a circle a couple of times and then tell you that you are now facing south and I tell you to turn 90 degrees to your right and I again ask you which direction are you facing and you say West and I tell you, No, you are facing South. Where are you?
You are on the North Pole and no matter which direction you are facing, you are facing South… L :D L . . .
You got me again. 👌
I forgot about that one, I'm following behind. :rolleyes:
Rod ..
Reactions: LoudThunder
Welcome to the forum! :)
FNG_
