Hi all
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi FaustoP Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Mini manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
Welcome to the forum! :)
just received my Mavic Mini this afternoon
Here are some things to help you get started with your Mavic Mini:
  • The current Mavic Mini manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Mini downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Mini manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Thanks everyone!
I've been involved in different communities forums in the past but I can't remember any warmer welcome! :)
Thank you so much, yes I will share my experience as soon as I improve a bit. I did some practice in the last weeks with a Mavic Air from a friend but still need to improve at the controls :)
zohpar
