Natedoggz
- Joined
- Jan 25, 2017
- Messages
- 180
- Reactions
- 75
- Age
- 41
66,800mah is the powerall, and the cheap china chargers charge at 12.5v instead of 13.4v like dji chargers start at!
Hello everybody and thanks in advance for your help
I´ve been reading some threads here, but none of them clearly explain that.
I am terrible with electricity...so basically I don´t know much about Amps, and Volts...I just know a bit.
All the threads I´ve been reading always deviate too much into electricity discussions or mods impossible to understand for a person like me.
So my question is simple.
Is there a portable power bank out there on the market, capable of charging safely (for me and for the battery) one battery of my MP?
My question is to solve a very common problem that happens to me. I sometimes hike in the mountain for 3 days...and just 4 batteries is not enough to fly all weekend...so...I accept other ideas than the power bank too!
No intention to find mods or things like that...just the right power bank...
THANKS!!!
You could use a DROK to step up the voltage to the required level, I have seen others do it. I haven't tried it myself yet, I have been considering using a large car battery and hooking up a DROK to it to output the desired voltage but I don't have any need for it at the moment.
Here is someone charging the Mavic battery from a 2s (7.4v battery)
That's interesting, maybe there is a voltage step up converter in the Chinese charger. I saw another video where the guy was using a Chinese car charger with the car off, which means that one was also charging at around 12.5v.
EDIT/ here's the other video, charging with the engine off.
I use a DROK on my DJI car charger. Voltage is now stable, but if your power supply can't supply full current (~5amps) then the battery still won't charge.
I wish there was a way to trickle charge these batteries but it doesn't seem like there is.
They have a solar power 1 a little more $, but u can use anything that can start a true V8 gas truck should work, i didn't spend a lot on it because I use them for work and they last about 30 full drains of the power pack for regular vehicles, I have no true long term tests for mavic batteries as of yet, but have noticed some of my compacity has gone down slightly!
THANKS!!!
Hey, yesterday i buy one.. Output 12 volt, 66 amps and 5 volt connection for the remote control and telephone. [emoji106]. Look on Aliexpres for a power jump.66,800mah is the powerall, and the cheap china chargers charge at 12.5v instead of 13.4v like dji chargers start at!
Not mavic, the power packYouve noticed some of the Mavic batt's capacity has gone down a bit? What do you think causes that?
