Mavic mini loss of RC signal
Craig Notts
Nottinghamshire
Hi all
Just got my lovely mavic mini and first took it over farm land with no issue. On my next flight I flew over my my housing estate at about 150 feet height just to test reception and a couple of times got a message saying loss of RC signal and it performed a forced rth whilst only about 800 ft distance from me. This happen again from even closer range. There is a large mast in my local park that is about 400 metres away from my home point could that be the reason.
Hi all
welcome to the forum ,not the best idea to fly over your home area you will get interference from all the WIFI in the area plus you could upset your neighbors better to go somewhere less populated
Welcome to the forum, and enjoy the new hobby.
It brings a whole new perspective.
Be aware signal loss is often caused by reduced LOS due to 'things' in between the controller and aircraft, trees can block a lot of signal once you get far enough away to bring the LOS down enough.
WIFI from the homes could cause problems too.
Lastly, ensure your controller antenna are positioned to best effect towards the mini, as per the manual.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
mountainmanflyin
