Mavic Remote - Lower USB Video issues
sidonsoft
Connected my phone to the lower USB today and the video was choppy and freezing and there is a 2-3second lag on the video stream when it is working. The rest of the data seems to be ok in the Go 4 app.
I tried changing to different USB cables, 3 cables in total including the included cable with the Mavic. All have same result.
The side port the video works fine but it is too short to reach my Android phone. The side port works fine for iPhone 6 plus but have no tried it with the lower USB.
The side USB cable is removed while using the lower, any ideas?
DJI Go has better video stream but it is still very poor but atleast I can use it. DJI Go 4 app is pretty much unusable
Disabled Caching, changed from 20ghz to 10ghz and back again but it not a signal issue.
iPhone 6 Plus with side cable works as intended, will still need to test with lower connector.
If you have any ideas, please share them as I am running out of things to try.
Have you tried any other devices.... both my phone Samsung 7 and Tab s2 work perfectly
odofi
