NLA
Dogpilot
Flagstaff, Arizona
Leaving on a trip for about a month, so be off line. Pelican 1510 airline carry on for cameras and drones. Comes with the TrekPak divider system with extra dividers and pins and foam cushions. A wonderful case with lots of storage. Just have not been using it much lately. IN decent shape with some wear from normal use. Not beat up, I take care of my stuff. I also have uncut foam inserts from high density foam. I will include them, but shipping goes way up due to the dimensional nature of shipping now.
$250 + Shipping and I will split PayPal fees. Shipping depends on where you are and if you want a quote, the web pages want your complete address. PM me for more information.
Manufacturer blurb:
DIMENSIONS​
Interior (L×W×D)19.75 x 11.00 x 7.60 in (50.2 x 27.9 x 19.3 cm)​
Exterior (L×W×D)22.00 x 13.81 x 9.00 in (55.9 x 35.1 x 22.9 cm)​
MEASUREMENTS​
Lid Depth​
1.79" (4.5 cm)​
Bottom Depth​
5.79" (14.7 cm)​
Total Depth​
7.58" (19.3 cm)​
Int Volume​
0.96 ft³ (0.027 m³)​
Padlock Hole Diameter​
0.31" (0.8 cm)​
OVERVIEW​
The original case introduced over 45 years ago has since evolved into the global standard for equipment protection. The Protector Case series is designed to survive and trusted to travel to the harshest environments on earth.
The Pelican 1510 Protector Case provides military-grade protection for a wide variety of gear, from camera equipment to camping kits. It is available with foam, without foam, padded dividers, or TrekPak dividers. The Pelican 1510 Protector Case is the maximum airline carry-on size, so you can travel with your sensitive gear close at hand.
  • Maximum airline carry on size*
  • * Check with your airline for exact measurement requirements.
  • Watertight, crushproof, and dustproof
  • Strong polyurethane wheels with stainless steel bearings
  • Open cell core with solid wall design - strong, light weight
  • Retractable extension trolley handle
  • Easy open double-throw latches
  • Stainless steel hardware and padlock protectors
  • Automatic pressure equalization valve - balances interior pressure, keeps water out
  • Comfortable rubber over-molded top and side handles
  • O-ring seal
  • Personalized nameplate service available
  • Lifetime Guarantee of Excellence
Whitehammer661
