North Georgia
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Hello from the Crossroads of America JPayne
Nice to meet you Johnny. 🤝
If you havent done it yet, you should register the aircraft with the FAA and take the TRUST test and keep a copy with you when you fly.
Good luck and welcome to the Forum. :cool:
Hello, my name is Johnny and I live around 60 miles North of Atlanta Georgia. I purchased my first drone a Mavic Air 2S.​
Welcome to the forum. You live in a wonderful area for flying drones. Using the FAA's B4YOUFLY app I didn't see any restricted or prohibited areas nearby. The Atlanta area is a very different story.
Here's the online version of B4YOUFLY. The DJI Fly app provides information on restricted and prohibited areas, but B4YOUFLY is the ultimate word. There's a phone app, too.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
I see that @MA2 317 has already given you the heads-up on the TRUST Certificate, but your drone weighs more than 250 Grams so it must be registered…
Link to the FAADroneZone (Registration for Drones over 250-Grams…)
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Welcome to the forum, Sandy Springs, just south of you. We look forward to your participation and your view of the world.
Thank you very much. The links you supplied are a gold mine of information.
I did register the aircraft with the FAA and have taken the TRUST test. I don't plan on using my drone as a business , but will take the test FAA 107 sooner than later. Thanks for the reply
Happy Droning…
Thank you for the helpful information. I am slow and steady when flying. I was surprised at the learning curve . I have operated equipment that had joy sticks and thought I would take to the drone fairly easy, but that's not gonna happen.
Reactions: SeaPig
To help keep the responsiveness down and keep it slow, keep the drone in Cine Mode and I recommend that you removed the Throttle Stick. Sound weird, not at all; you can still give it throttle and Yaw by rolling your thumb on the ball gimbal…
You place your thumb on the case just below the throttle ball gimbal and push it slowly up and you will have complete control. If you do the same with the Pitch/Roll stick, you can hold that drone is such a slow forward movement that it might lose a race with a slug…
I often do this when I am flying in a nice slow Video shoot and I do not want to make sudden movements.
Keep it low and slow, Good Luck!
clang123
