lenabanana
- Joined
- Feb 28, 2018
- Messages
- 126
- Reactions
- 86
- Age
- 36
I'm going to give it a try when I finally get my drone back from DJI later this week.Yes, but only the startup will say "SHAREWARE" and the startup/shutdown sounds will become a bit longer. It's always possible to re-flash the original firmware.
No, donating is tied to the RC, not to the firmware version. Once you donate, that RC can be flashed over and over again. After you donate, you'll have to flash the RC again to make it completely silent and restore the "CONNECTING" at startup. It's possible that an upgrade/downgrade of the RC overwrites the patch. In that case you can use SilencioRC to restore the patch again.
Firmware releases for the RC (and for the drone itself) consists of different components. For the microcontroller that gets patched, only 2 versions exist (since 01.03.0200): up until 01.03.0900 was one version, from 01.03.1000 until current uses the second version. It doesn't change that often. If a new firmware release comes out we'll do our utmost best to get that patched as well but I can't make promises that we'll always succeed... It does work for all versions released so far.
In the future, I would love the option to select which sounds are silenced! For example, I kind of like the startup and shutdown tones but the RTH and low battery beeps are awful.
Either way, I'll be donating to remove the shareware tones and will report back once I test it!
