Sold my Spark, so moving here as my DJI Mini 3 will arrive today
Hello from the Crossroads of America tahoejeff.
I'm a former Spark Pilot too. 😊
It still flies fine but the gimbal is compromised after a low battery RTH up into the tree canopy. D'oh!
Just about had it in my hand and up it went. :D
13 minute Spark flights.
I'm impressed with the 25 minute flight time of the MA2 and when I first flew it, I would head home with half a battery since I was used to the short flights of the Spark.
Have fun with the mini and welcome to the Forum. :cool:
My Mini 3 will be hitting the skies over Baraboo WI soon!
As a New Drone Pilot of a "New Drone", there are a couple of Legal Things you may need to do, in case you did nto do them previously…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone, but if your Spark was registered, you might want to add it to your account…
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Wisconsin, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 (non-Pro) and the Pro (you did not say which you were getting), including the User Manuals.
After you read the Manual (of the drone you have…), read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Thank you for all the great info and links!
Thank you! That RTH got my Spark as well when my battery was getting too low. Just barely clipped a power line, causing a crack in one of the props. I was lucky!
Mini is here! Unfortunately Amazon won't bring my 30w charger until tomorrow.
Charging the remote with phone charger, and reading manuals/watching instructional videos until then. ;-(
Reactions: LoudThunder
Welcome Jeff, good to see you register here.
This forum is very busy compared to SparkPilots, understandable given the Sparks obsoletion many years ago.
Enjoy the Mini 3 and it's many flight and camera upgrades from the Spark.
Thank you for the welcome, and for helping me find this forum!
You're welcome mate.
It is certainly very active here, peoples questions are usually addressed fairly promptly and knowledgably.
You should be able to find a lot of little things out just reading the Mini 3 forum, and using the search function, along with YouTube tutorials etc.
You're probably quite competent flying the DJI drones after the Spark, not a lot different with the newer drones, just little idiosyncrasies to get to learn and get the most out of improved features.
Enjoy.
bullet_magnet
