teslar
- Joined
- Nov 13, 2016
- Messages
- 117
- Reactions
- 57
- Age
- 69
Looks like a good cable, a little on the long side though, 20".
0.2M is about 8" I think you misread [emoji2]
Thanks for the video, unfortunately as suggested it seems they may have slightly tweaked the design of the controller so the ipad mini 4 no longer fits as shown here.
Here is everything you need to know about Mavic and tablets. Also he has links to his cable and other items
Sent from my Pixel XL using MavicPilots mobile app
Wow, now I have to wait until next Saturday to find out. I almost just ordered a Mini 4. Anybody have a way to show the two controllers show we know which one we have?Wow that is a great feature to lose. I actually just measured my cable and it is 8.5 inch's long. I also had to do the trick to deemed down the area to avoid the sports mode. That is interesting to see that slight change. I would like to see a sticky poll asking how many are affected with this.
I think the tweak may be to stop the holding arm hitting the sport mode switch, mine can't hit the switch but it seems some can, wish they'd moved the switch instead!Wow, now I have to wait until next Saturday to find out. I almost just ordered a Mini 4. Anybody have a way to show the two controllers show we know which one we have?
I figured that too, however appears to be the main casing that is limiting, could cut into it but may look at other options first...Betting it's something simple, like a stop of sorts. If so, perhaps it can be modded to open up a bit more.
Awesome, ThanksJust to correct this, I have an iPad Mini 4 with a newer controller and it fits in the controller just fine, (my Mavic arrived 12/5/16). Also it does not interfere with the Sport Mode switch at all. I can switch modes back and forth easily with the iPad Mini 4 attached...
Could you show the issue with yours?Well it definitely isn't the case with mine, will be intrigued to hear if others have the same issue moving forward.
