1 Smart controller for both M2P and M2Z
barrybcar
Boise Idaho
I tried a search but may not have entered the right words...
I have a SC and a M2P that are linked and work fine. I just got an M2Z and would like to use my SC with it as well, hence my question...
Can I use the same SC with both the M2P and M2Z or does each require a dedicated controller??
Yes the SC is compatible with both devices and will control one at a time. You just need to link it to the SC.
the best way to set it up - in the SC go to android options folder/menu after swipe down the screen after booting up - and you will see a 'Switch Aircraft' menu. Get in there and do 'Add Device' - it will make a model for you current connection, name it. it will make you to reconnect. for next drone, click 'Add Device' again and connect to other drone, etc. It is extremely convenient to use afterwards.
Yup - there is a little pairing button under the covered port opposite to the memory card slot on the bottom of the M2, it takes only a few seconds to pair a new controller or re-pair it.
so, when a SC setup with multiple models as i explained - you do not have to pair it anymore, it just works automatically upon selecting the saved model on the GO4 screen.
Yes, I did not say otherwise, I was telling him how to pair it - I thought that was obvious given the previous replies, sorry for any confusion.
wbrian
