21 images for horizontal pano?!?!?
GroovyGeek
San Diego, CA, USA
Today I tried for the first time to do some still panos with the new (to me) Mavic 3 Pro.
  1. Vertical pano - 3 shots
  2. Wide angle pano - 9 shots
  3. Horizontal pano ..... 21 shots?!?! Whiskey Tango Foxtrot...
Anyone knows what's going on and how to fix it?
21 shots seems to be normal. 7 columns of 3 shots each. Center column with three columns to each side to cover 180 degrees if memory serves me. Give Panovolo (member of forum) a free try. It has worked well for me and it will produce a DNG file -if you shot your original pano in DNG. I have a good experience cropping the center of the 21 file pano to get what I want.
21 images is correct for a 180 degree panorama which is three rows of seven images as mentioned above so it gives quite a wide field of view. While I find the 180 shot is usually too wide to use on its own I find it the most useful mode for panoramas since it gives a lot of flexibility for choosing a suitable crop afterwards.
If you just want normal single row horizontal panos, I just shoot manually with about half a frame overlap and stitch in Lightroom Classic. Does a great job with no stitching errors, and a choice of geometry. Most editing apps will do this.
Reactions: GroovyGeek
Thanks for the comments everyone. Yes, I was just looking for a quick 3-shot horizontal pano option. As noted by @BingBong above I can do that manually. I do my own pano stitching anyway.
The 21 shots is a) just too many files to deal with and b) takes too long for the files to be streamed to the microSD.
Reactions: BingBong
M5P
