Hey Guys,
I´ve developed two new Range Extender 7-Element Yagi versions for the Mavic Mini (CE) on 2.4 Ghz. They are computer optimized with 4NEC2 an antenna modeling software. It took me quite long to reverse engineer the rf-parameters of the original dipols of the remote, because they use dual band antennas with shortend dipols and capacitors at the end. The standard Range Extender Design for 2.4 Ghz with the 5-Element version which goes around the last months is not bad but hasn´t the best SWR ratio, so I decided to do better
The standard 7-Element version has about 12.4 dBi gain with a length of approx 15 cm and the long version 13.4 dBi with a length of 20 cm. I´ve done some measurements with the RF Power Meter V2 from ImmersionRC and the values seem to be realistic. Attached you find photos of the antennas and the radiation characteristics. My first tests were very promising but I´m living in a very dense populated area in Germany and I have to find a good place at first where I really could fly out the limits.
Cheers
Cheers
