Install new Prop(s)Sounds like a middle school math problem. And the answer is?.....
Within what radius do I have to look for the loose Propeller?
I don't know which technical genius here that you seek, but I have 2 questions for you:And likely direction where I can find the propelle
what you have spoken about here is one of the reasons that i always remove my props on my MPP it enables the lugs on the prop hubs to be checked for damage and gives a chance to to check the screws that hold on the prop hub to motor fixing, it is imperative to make sure that these screws have thread lock on them if they are removed for any reason and that their tightness is checked during airframe inspection ,also the spring that tensions the prop in the fixing could lose tension over time ,and just check how high it comes up the motor shaft when the prop is offI am a little surprised that no one has asked the question, why did the propeller unload?
In this case, it is not the mistake of the pilot during the flight, but poor control of the drone's condition before flight, in this case my fault.
I show a picture with the drone's right front arm with engine, here you can see that the black top, with white circles, which help to attach the propeller's Hub to the engine, is missing.
Why do you have to ask, the answer is in the way I use my drone.
I fly, almost always and almost always everywhere, especially in forests, where it is impossible, at least in my opinion, not to suffer a crash every now and then.
The most delicate on the drone during such a crash are the propellers, a particularly vulnerable pair is the Hub that attaches the propeller to the drone. Here are three heels that attach when turning the propeller when inserting into the engine.The strength of the material that the Hub consists of varies between the different propeller manufactures.
In other threads here at MavicPilots I have written about what I consider to be the most durable, propellers and Hubs and the technical solutions for how the propeller blades are attached to the Hub.
IMO
- The most durable plugs, Carbon fiber
- The most durable Hub, Master Screw
- Best technical solution, Carbon fiber
I therefore use:
- Proppelrar, Carbon fiber
- Hub, Master Screw (not the best technical solution, but the only one that can be used)
In the event of a crash, one of the hub's heels may remain initu locking devices, the black on the top of the respective motor, thus must be unscrewed to remove residual from the broken hub.
Apparently, I have neglected to check the re-attachment of the black locking device were drawn hard enough , so that the three screws have vibrated loose and Bang, here we have the crash.
New point in the checklist for each flight: Check that these three mentioned screws are well tightened in each engine, and that the two screws that hold each probeller blade to the Hub are well tightened. Screws that have a crucial function for safety should have lock washers and tighten with tensioning devices that can measure the force of tightening, unfortunately all screws in our drones are far too small to allow such a method of operation.
A couple of years ago I did some experiments with a P4 throwing props at that kind of rpm. I'll see if I can find the videos to confirm, but they ascended around 5 meters before coming back down. Total flight time was several seconds. That suggests that in a 5 m/s wind and an initial height of 2.5 m you might expect it to travel around 20 - 25 m.
