That is what I found to be correct. The first shot in a series of 3 looked better than the following 2.
Thank you,
Chuck
Hey Gold. A bracketed shot is one that allows you to create an HDR (high dynamic range) image. Typically, one or more images are over exposed and similar number are under exposed. And one is juuuuuust right (or so said Goldilocks). What this allows you to do is merge them in programs such as Adobe Lightroom.
Taking the series of shots for an HDR is useful when trying to capture an image when there is quite a dynamic range of lighting conditions. In other words, very bright areas (such as clouds or snow covered fields) with very dark areas (such as areas in shadows or shooting towards the setting sun). In post processing, you can often tease out details in both the shadows and the highlights. Our eyes and brains allow us to do this ourselves. Cameras aren't yet that sophisticated.
You can take HDR shots manually but you'll need a very stable platform to prevent camera movement. I used to do this with an older camera of mine. Properly expose the view then, for example, take shots at -2EV, -1EV, 0, +1EV, +2EV. You can also shoot -4EV, -2EV, 0, +2EV, +4EV. Or even mix and match . . . experiment away! AEB functions simply automates this for you. You'll need to process them on your computer. HDR does this in-camera. Although I'm still learning how to best take bracketed shots with my Mavic, with my A6300 for example, the in-camera HDR is not nearly as good as one processed using Lightroom.
Not to blow my own horn too loudly, but if you look at the very first image on my website (currently beams of sunlight piercing through clouds onto a storm tossed lake and shoreline) you'll see a great example of an HDR shot.
https://iandavis.photography There is no way our current cameras can record, in a single image, the bright sun and dark waters. (I shot these on my Sony A6300 in RAW. The Mavic RAW format is DNG.) I think I combined 5 shots for this particular one. 2 under exposed + 2 over exposed based on the primary shot settings.
A tip: if you aren't sure about the accuracy of the camera sensor readings take a bracketed shot and choose the best one even if you have no intention of creating an HDR image. Sometimes I will take 7 or 9 on my Sony just because.
Automatic Exposure Bracketing (AEB)
