Aftermarket Propeller or Skin?
Jgruberman
Dallas
I purchased a pair of MAS Propellers for my MA2 and an aftermarket skin. Is there any issue with using either of these, primarily for flight performance, weight, etc? I just wanted to make sure any aftermarket changes I made didn't impact anything negatively. (Links above on each text item)
Reactions: tlswift58
Not sure about props, but I have that same skin for my Mini 2, other than looks, i dont think it add/takes away anything from the my drone's performance.
McG
the items you mentioned should not be detrimental to your drone ,the only time a skin can cause an issue, is if it has a metallic foil layer in it that can cause issues with the compass and the drones ability to lock onto sats
Reactions: Jgruberman
I didn't assume so since weight has to be extremely minimal addition but wanted to clarify in case there was some sort of "legal markings", "non-permissible colors", etc. Personally, I thought it would be good for added visibility but being new I didn't want to make any incorrect assumptions.
Reactions: old man mavic
I've been flying with a Decalgirl skin for a year with no noticeable impact on flight characteristics or endurance. Still using "factory" props, so can't speak to that.
MAS props work fine on my Air2. Skin should be no issue either (non-metallic vinyl).
If you want visible - invest in some strobes - good ones.
The skin will help is bright colored.
I've seen no real visibility enhancement with the MAS red props. Can't say any of the other "benefits" work either, as I don't test the batteries to see if they fly longer or faster.
I did have strobes in mind, purely from a visibility perspective. Any recommendations?
People on the forum whom have bought "Firehouse" strobes highly recommend them. Not cheap though.
Reactions: MA2 317
proya12
