- Joined
- Feb 28, 2018
- Messages
- 19
- Reactions
- 2
Thank you Yes, I did the update normally, then when I had the issue pop I went over and true the Refresh from the DJI assistant, I tried it like 5 times, even with different batteries. I have the latest version of the fly app, downloaded straight from the DJI website. It didn't fixed it and now there no way to get the old version back like it used to before.Did you apply the update over the air?
Try updating the firmware of the drone and RC using the DJI Assistant. And check the Fly App version.
There is a way to get the old version of the Fly App.Thank you Yes, I did the update normally, then when I had the issue pop I went over and true the Refresh from the DJI assistant, I tried it like 5 times, even with different batteries. I have the latest version of the fly app, downloaded straight from the DJI website. It didn't fixed it and now there no way to get the old version back like it used to before.
This is the kind of stuff that makes me wonder if I did the right thing by buying one of these “top of the line” drones.Frightening. Please post back if or when you fix the problem. Enquiring minds want to know..the solution.
New update, sent the drone to DJI. Their diagnosis was "Gimbal Axis Arm Module jammed/stucked".Frightening. Please post back if or when you fix the problem. Enquiring minds want to know..the solution.
