Air 2s heating up on the underside
rmoran8994
Kansas
Even on short flights, my Air 2s seems to get really hot on the underside of the drone. Is this normal? It seems extremely hot to me.
welcome to the forum!
mine gets warm on the belly also, but not too hot to handle.
check if you have any vents blocked.
IT'S NORMAL FOR THE AIR2S. It gets really hot. The batteries easily get over 70 or 80 C when flying in 90-100 F degree weather in sport mode. I've had mine for 2mnths and talked with other forum members about it. The experienced ones concur that it's normal and nothing to worry about. I've really pushed my Air2S and have also flown it with considerable weight loads attached while in sport mode. The batteries haven't swelled and the app has not issued any warnings. I've learned to be ok with it. As a usual preflight check, always check your batteries for swelling, if you see any, don't use the battery, it may pop out or cause a malfunction.
Reactions: Thomas B
Another thread on the AIR 2S :
Phantomrain.org
Gear to fly the AIR 2S in the Rain.
I just added my 2 cents to the other thread.
Reactions: Phantomrain.org
Overspeed
