Thanks mate, that worked.It should pop out if you find something thin to push against the top of the card to depress it.
Use some fine tape on the SD card such as sellotape, fold it over the non contact end, make sure that an amount of tape extends enough to hang out of the cover/flap this tag will allow you to pull the SD card out change it on a regular basis as it will weaken but it will save you hours of agro!It should pop out if you find something thin to push against the top of the card to depress it.
I carry a set of tweezers. I use them to click in and to also click out and remove the SD Card. Fat fingers with short nails.
Works too! I have 2.I created this Micro SD removal tool to overcome this problem:
