Air3/3S battery charge speed & charger discussion
BenThe
Canada
Hello everyone!
I tried charging the Air3/3S batteries for the very first time a few days ago, but I have a problem: I have 3 Air3S batteries and one extra genuine Air 3 battery, along with one original 3-slot charging hub. I hooked it up to a 90w charger that came with a phone, but the charging speed was extremely slow. We are talking >15 hours for one Air3S battery from (1 solid one flashing light) to full, and it has taken way too long to charge up the four batteries. This 90w charger supposedly have PD as it outputs 5-20V at 5A.
I tried to speed it up by placing one battery in the drone and charging it through a 5V2A charger that does not have PD, and it took roughly the similar amount of time. That probably indicates I do not have 90w at the charging hub. Before I spend more money on a new charger, how is everyone's experience with the charging speeds?
If I have to spend money on a new charger, would this one work? Thank you!
toocki 140W USB C Charger Block 5 Port GaN USB C Charging Station with Digital Display, PD PPS 100W Power Adapter
I haven't used that one, but it should work.
If you're looking for something a little more compact, I'm using the 100W Anker Nano Charger to charge my Air 3S batteries.
Yx parallel chargers are a nice option. The only downside is you need a separate charger for nearly every drone model.
Reactions: Cafguy
You're using the usb-c to usb-c cable, and not the usb-usb-c right? It charges much slower with the usb to usb-c cables.
I use a Anker 90W with usb out and 2 usb-c ports.
DronerMax
