Alternative to my current Tablet
Italy
Hello everyone,
I have always used a Xiaomi Mi Pad 4 as a Tablet associated with the remote controller with my drone.
After the last use, I started to think seriously about an alternative, because of the difficulties of consulting the screen in the sun.
I wanted to ask, kindly, for some suggestions for an Android tablet, with a display of around 8 inches and a SIM slot in order to possibly replace mine, which has a good degree of "visibility" of the screen under the sun...
I also imagined using those "parasols" to attach to the remote control/screen, but I don't know their goodness and practicality.
Does anyone have any suggestions?
Thanks.
I think the Tripltek is the one that folks go to when they want/need a brighter screen. But the weight of the Tripltek by itself before you add the tablet holder is 1.37 pounds, 600g. In contrast my iPad Mini6 weighs 10 ounces/ .625 pounds/ 293g (no m/s), less than half the weight of the Tripltek, but admittedly is way lower in nits. You'll need a heavy duty tablet holder too. A tablet holder like the one shown below weighs next to nothing and costs only $10 and takes 2 second to install. A heavier bracket will take time for you to set it up, even before installing the Tripltek to it. . You might find a heavy brackets to add an additional 8oz/225g. I also own a bracket similar to what you'd need for the Tripltek, but didn't need a super heavy duty one to hold my 293g tablet. I rarely use it simply because of set up time needed for it so I use the one below for my Mini 2, but need the other one for my M2P.
I was going to suggest a smart controller as an alternative, but in doing a bit of googling DJI makes it as confusing as possible as to which one you'd choose for a given model.
I'm not in any way suggesting that you not buy a Tripltek. It is probably the best thing going when you have to be flying out in direct sunlight. I only bring up the weight issue because it's something I wrestled with last year and decided that I didn't want to fight with that much weight.
Just putting it all out there to consider.
Reactions: Soar Like an Eagle
Here are the pics of the Lanyard and Tripltek Tablet mount.
Works great together.
So alternatives.
1000 nits or better
DJI CrystalSky 2017
DJI RC Pro 2021
Tripltek
Tablets that meet the following criteria required for the Fly App:
Android 6.0 minimum
64 bit hardware and OS
3 or 4 GB RAM.
With GPS (not required but a benefit)
Compass(not required but a benefit)
Confirmed, Works on:
MM2
MA2
MA2s
Above specs verified @ GSMArena.com - mobile phone reviews, news, specifications and more...
Android Tablets
Lenovo Legion Y700
Huawei MediaPad M5
Samsung 8.7" Galaxy Tab A7 Lite 32GB Tablet
Samsung Tab А8 10.5 Wi-Fi SM-X200; Galaxy Tab А8 10.5 LTE SM-X205
Samsung Galaxy Tab A7 10.4
Samsung S5E
Samsung Galaxy Tab Active3
Asus Zenpad Z8s ZT582KL
The attached list is tablets only pulled from phantomhelp.com - best-tablets and phones. Some have the nits listed.
Hope this helps.
Guys, I want to thank you all!
You gave me very good suggestions!
Cheers from Italy!
I got a call last night from a friend of mine. He flys a MA1. He recently the latest Android phone (i use apple so i have no idea which one) and he said DJI Go 5 will not link with his drone so when he put DJI Go4 on his phone it causes his phone to crash. Any thoughts???
I was hesitant to switch to Apple from Android, after years of flying and having many disconnects. I finally made the switch and never going back to Android for DJI. Get a renewed Apple Ipad mini 4th gen on Amazon for around $150. If sun is a problem, buy a visor or you can make one yourself from a sheet of black plastic from a crafts store, Youtube "dyi visor drone tablet"
tortoide
