altitude
W
now other than that unless im required to reveal anymore then im not doing like i said before pull the stuff out your ears to all you doubtfuls the thing just flew away that day tske it or leave believe or dont
mmm, I’m thinking this is not the forum for you fella. Generally we are all here to share and learn from each other and share our experiences. Some of us don’t agree, but there is still a level of respect among us. You have arrived here and behaving like a ****, sprouting a story that seems strange and getting all antsy when queried.
My guess is that you will not supply the correct logs.
Maybe take your keyboard warrior attitude back to Facebook.
As in legally or physically possible? Legally depends on your country this is one you should really know already ?. 400 feet is the typical legal cut off though. That’s plenty high.
The Mavic Pro stock has a software limit of 500m above the take off point. However, if modifying the software limits the max service ceiling is 5000 meters above sea level. I really doubt there are many places you could take off from, reach that height, and then make it down on one battery though.
Short answer higher then you would want or should go
400 ft above ground level or above a building or ground feature. As for capability I have taken off from 12000 ft above sea level and had no problem climbing or maneuvering.
This is close the the maximum.
31,850', yea that's about the top end for sure.
Look a little bit around, here at mavic pilots or youtube, it is a theme very often discussed. There are heights the drone went 4300 m, one clip I remember was over 5000 m. Look around...
how is it modified to make it go that high. after 5000 feet it starts getting very cold very fast. I also think with the small props and thin air at high altitudes it would be very hard for a small quad to get that high.see temps at high altitudes
20000'-12.26
25000'-30.05
30000'-47.83
35000'-65.61
20000'-12.26
25000'-30.05
30000'-47.83
35000'-65.61
I know he’s put phantom motors and props on it and I think a battery mod of some sort but I agree it’s hard to believe.
Rather than guessing, it takes about a minute to find details from the Russian flyer that did this.
There's no mention of Phantom motors or props and it sounds like he's used a purpose built drone for the attempt.
Here is his description using Google Translate:
March 9, 2018 - Russia, Strezhevoy. Experiments with quadcopter continue. At this time, the purpose of the flight was to reach a height of 10 kilometers (33,000ft) and return safely to the launch site. Due to numerous requests, by his own will and not without the help of good people, a display of air temperature appeared. Due to the inertia of the thermometer, the display of the current temperature does not occur immediately. It was about -10 degrees outside that day
The minimum temperature during the flight was -50 degrees Celsius in the region of 8000 meters. And there is also a desynchronization in time to a few seconds between HD video and recorded on the DVR (due to skipping or extra frames). Watch video with comments on the Anuara channel / Video with ENG subtitles:
controller software : inav 1.8.0 (osd custom modified)
Receive: TrueRC 5.8GHz X²-AIR Antenna RHCP - https: //www.dronematters.com/fpv/true ...
Receiver: Furious True-D V3.5 Diversity Receiver System US$68.00 15% Furious True-D V3.5 FPV Разнообразный приемник Прошивка 3.6 для очков FatShark Очков внимания RC частей from игрушки хобби и робот on banggood.com Video Transmission : Antenna FOXEER Thor 60mm RHCP / SMA PA1331 US$5.99 33% Foxeer 5.8G 3dBi TX/RX RHCP Omni FPV Антенна RP-SMA Male/SMA Male RC частей from игрушки хобби и робот on banggood.com
Video Transmitter Matek VTX-HV US$32.39 Matek 5.8G 40CH переключаемый видеопередатчик VTX-HV с выходом 5V / 1A BEC RC частей from игрушки хобби и робот on banggood.com
Control: TBS CROSSFIRE
Motors: Cobra CM2206 / 1400
Regulators: T-Motor f30a https: //goo.gl/AgwziJ
PC: Matek: f405-AIO (but now availeble new better version f405-CTR https://goo.gl/mTxSkC)
Propellers: Gemfan 7038 US$2.27 Gemfan 7038 Carbon Nylon CW/CCW Propeller For 350 250 RC Drone FPV Racing Multi Rotor RC Parts from Toys Hobbies and Robot on banggood.com
Battery: Build Li-ion 4s3p NKON | Sony / Murata US18650VTC6 3000mAh - 30A - 18650 size - Rechargeable batteries
Camera: Runcam Split 2 https://goo.gl/P9QrBR
Frame / Frame: IFLIGHT XL7 https://goo.gl/XxQPNq
Height and temperature was measured using a barometer bmp280.
If you look attentivly the clip you will see some scenes where the drone is flying upside down and still going up in altitude... This is IMO a fake as still discussed in the first thread.
Readers of this thread are you blind? Can't you google? There are enough clips at youtube showing the Mavic pro going up over 4000m. I don't need some obscure Russian clip...
Hi we are talking about the flight from this post. altitude
Now wether this is doctored or not I don’t know but I know @lolo780 has done a lot of stuff on to his bird and is well known in the modifications section of the forum. I have some ideas about what he has done to his bird and have seen other seemly impossible stunts so he has done Top speed so either he’s been fleecing us for a long time now or this is legit but I doubt it was done with a stock mavic
Sorry ... my mistake.
I concentrated on the altitude and didn't take the time to notice it's a DJI Go screenshot claiming a similar altitude.
Whatever drone it is/was, flying to that altitude is quite difficult and the chances of getting the drone back safely are slim.
Reactions: brett8883
I guess this isn't about Sandino anymore, and his flyaway bird with a mind its own.
Vertol87
