Andriod Users - Tip for Smoother Experience
Airmaxx23
St. Lawrence County NY
If you're using an Android device it may be worth turning on Developer Options then turning on "Force GPU Rendering". Depending on your Android version it may be worded differently. In Android 10 it's "Disable HW overlays (always use GPU for screen compositing)".
To turn on the Developer Options you need to go "about phone/tablet", then Software Information, then tap on the "Build Number" 8-10 times and you will get a notification stating the developer option are enabled. If you can't find easily Developer Options just search for it in the settings search box.
The GPU is much better than the CPU in graphics processing and is more efficient, forcing GPU rendering with make apps and the UI run smoother.
Mafis
