Will it benefit my using it if while flying the drone in some way.....If using an Apple device, you'll be able to use features that require GPS on the mobile device.
Not muchWill it benefit my using it if while flying the drone in some way.....
It will only benefit you if you're using the features @Meta4 mentioned above.Will it benefit my using it if while flying the drone in some way.....
How exactly would the map and radar be affected?It would also affect the map and radar
Unless you were to move a significant distance from the launch point, not much at all.How exactly would the map and radar be affected?
The only data that GPS provides is Lat and Long location data and time. It doesn't provide any mapping data.Cellular, or GPS? You can use Wi-Fi to download the data. However the question is if you need GPS to get accurate data for your area.
