Any way to split camera view from "drone view"?
Yves007
Up north
Hi guys,
I love the Mavic 2 Pro, but there is one conundrum I have with it. I'm taking a lot of low-level shots, say a metre off the ground, with tilting up or down of the camera. So the obvious problem is that when all you see on the monitor is the ground speeding past below, you don't see anything in front and it makes it harder to create these shots successfully. Do you have any thoughts about how one could go about have a "camera view" and a "drone view" on a split screen or two screens or whatever set-up.
Any thoughts?
Thanks a lot!
Yves
With a M2 i can think of a DIY solution:
Mount the DJI FPV air system (a camera with transmitter) on your M2, with the goggles, then have a second operator look at the 'drone' FPV view.
Hi guys,
Any thoughts?
Thanks a lot!
Yves
With stock equipment, no. As @Keule mentioned above, you could try rigging something but it could affect weight, balance, and performance. For such a solution using stock equipment, you would need at least an Inspire 2.
rubski123
