D
Sure I guess, if you were to fly in it could you get your ticket pulled?If you zoom in to the B4UFLY app that line representing the US Territorial Waters Boundaries is a few miles wide. Would like to know the real extension?
No. It's a flight restriction, not a flight prohibition, and the restriction relates only to flying near military vessels.Sure I guess, if you were to fly in it could you get your ticket pulled?
McDill Air Force Base is only about 50-miles southwest of this location and the Air Force might have that area either permanently or temporarily reserved for air operations.
MacDill Air Force Base > Home
Is there military vessels circling the us? Kinda cool thoughNo. It's a flight restriction, not a flight prohibition, and the restriction relates only to flying near military vessels.
The Gulf Coast is an area where military planes from NAS Pensacola and Eglin Air Force Base fly to practice many things; like target practice, dog fighting, many different maneuvers. On the map it might beView attachment 144956On B4UFLY I found thismrestricted zone off the coast and wondered what it’s for and if it actually matters if I fly there.
The notice the OP saw has nothing to do with the offshore warning areas in the Gulf. There are similar warning areas on every coast; they're the tan areas in the image below.The Gulf Coast is an area where military planes from NAS Pensacola and Eglin Air Force Base fly to practice many things; like target practice, dog fighting, many different maneuvers. On the map it might be
labeled; Warning Area. Don't even go close to it!!!
Department of Defense warning so do not even go close unless you want to loose your drone. This is even higher than the FAAView attachment 144956On B4UFLY I found thismrestricted zone off the coast and wondered what it’s for and if it actually matters if I fly there.
Warning Areas are a different thing. This is a Restriction that applies to coastal waters out to 12 nm. It's simply telling UAS operators not to fly close to military vessels. It's not a prohibition against flying in the coastal waters.Department of Defense warning so do not even go close unless you want to loose your drone. This is even higher than the FAA
Proponent | DOD |
Branch | USN |
Base | |
Facility | US Territorial Waters Boundaries-41 |
Airspace | Airspace over waters from US shore to line (12NM) |
Reason | NATIONAL SECURITY. See FDC 0/0852. Unmanned Aircraft (UA) operations are prohibited within 3,000 ft. laterally and 1,000 ft. above military vessels. Operating in the indicated airspace may result in disruption, seizure, or destruction of UA. |
