App settings going back to default by itself.
minimpw
Minnesota
Is anyone else having the issue of your app settings resetting itself? I went to fly yesterday all all my pre set settings are gone. It was all set to default.
The settings stored on the Mavic will always be reset after a firmware update. You should always double-check all of the settings after installing new firmware.
Hello,
I understand that settings are reset to default each time the drone is updated, ok.
But is there a way to save the settings and restore them all at once to avoid setting them one by one after each update ? Ok, there is not one firmware update everyday, but it can be easy to miss one setting before the first flights after the update.
If this does not exist, it could be a great feature of DJI Go app, that would also allow users to share their settings with others.
Thanks,
Yoan
No.
cbooth
