Are there any high pitch props or some kind of prop adapter for the Mavic Mini?
I seen when using it on mountains it’s often at its rpm limit and dropping in air sometimes.
Since the air is thin there is less load on the propellers so the motors will spin easier and draw less current at the same rpm the props will produce less thrust.
All we need to do is get the current draw back up, without having to swap out the motors for higher kV, that leaves us with the props.
We could use longer props (since it appears they can overlap) or higher pitch props, or more blades with a prop adapter.
